PCM question (again)
Old Apr 10, 2007 | 11:00 PM
ckt_santiago's Avatar
Ok, now, I need to know if anybody knows whether or not the PCM changes the speed sensor signal before sending it to the speedometer. If it does then I need to know if anybody knows whether or not they make aftermarket speedometers that can be dialed in to read direct feed off the speed sensor.
Old Apr 11, 2007 | 10:18 AM
infidel's Avatar
The PCM changes a pulse count signal from the sensor to a variable voltage at the speedo. This voltage signal is also used by the cruise control.
Couldn't tell you about the aftermarket.
Steven K
Jun 4, 2009 10:32 AM
Big Perm
Dec 18, 2007 08:44 PM
b84u
Feb 20, 2006 01:04 PM
gunracer1
18
Nov 24, 2003 08:56 AM
Sean S
Nov 15, 2002 12:25 PM
