Pan Gasket
Old Jun 28, 2005 | 10:23 AM
zack_76401's Avatar
From: Lingleville TX but active duty Air Force all over the world currently
Pan Gasket
Going to replace the pan gasket on truck in sig. AGAIN. Should i stick the gasket to the block and screw the pan up dry. or should i stick the gasket to the pan and then throwit up with no sealant between the block and gasket.
Also where do i ge tthe marine rubber return lines long enough to go from tank to IP?
My boss told me to seal the gasket to the pan and use sewing throed through the bolt holes to hold it inplace on the pan while i throw it up on the block? I cant get this Son of a gun to quit leakin......
Old Jun 28, 2005 | 01:40 PM
Haulin_in_Dixie's Avatar
When you have the pan down, look the bolt holes over real good for cracks at the holes. That is what is wrong with mine. The service manual says to use sealer around the ends and a few inches up the sides. I always use a piece of stranded wire, stripped a couple of inches and cut off. The individual strands of copper will hold the gasket up without causing a leak. An old man, taught me that... and now I am the old man
Old Jun 29, 2005 | 12:58 PM
zack_76401's Avatar
I dont quiet understand about the wire......put it through the panthen fold the unstranded wire down onto the gasket before i throw it up?
Also, what your sayin is just use sealant around the corners or the front side and rear side of gasket then keep goin a couple inchesaround the corners up the straigh sides of the gasket?
Old Jun 29, 2005 | 05:25 PM
Sorry I'm late I was on the road. Take the individual stands of were apart and put a strand through the hole and gasket, twist it tight, leave it there, of course to the outside of the pan, not inside.
On the sealant that is what the book calls for, but if you have an existing problem, seal the sucker up, won't hurt that is for sure.
Old Jun 30, 2005 | 11:30 AM
zack_76401's Avatar
rog, gotcha now same thin i was gonna do wit sewig thread...ill try this..thanks man.
ps still burning oil?
Old Jun 30, 2005 | 11:35 AM
zack_76401's Avatar
ps what sealant should i use? someone told me gorilla glue but i didnt know you could use this on gaskets..i usually use the purple stuff..dont know th ename of it i call it grape jelly.....any reccomendations?
Old Jun 30, 2005 | 03:10 PM
hy temp RTV. and the ps, 6000 miles since change and no added oil. Now my frame can rust
Old Jul 1, 2005 | 07:42 PM
pmtg's Avatar
wasnt there a TSB for the oil pan gasket? i thought it showed the preferred placement of sealant... hmmm...
i am on a slow computer otherwise i would check out dodgeram.org for you.
04ctd
Apr 21, 2008 03:16 PM
EverydayDiesel
Nov 11, 2007 09:33 AM
tex23455
Jul 25, 2007 02:31 AM
MrKen
Nov 23, 2006 03:19 PM
bostongsx
Sep 25, 2006 11:25 PM
