P7100 question
Old Aug 13, 2009 | 08:25 PM
MrExtreme's Avatar
P7100 question
I found a P pump that has the number 0-402-739-909 the 230 HP pump is 911, how much differnce do you think there could be in the 2 digits?
Anyone know, opinions, should I just go for it, it is only $325
Old Aug 13, 2009 | 10:07 PM
MrExtreme's Avatar
Never mind, I just bought a 250 HP marine pump, that oughta fuel well!!
Old Aug 13, 2009 | 10:27 PM
Tate's Avatar
FWIW, the 911 pump is a 180 pump, not a 230 pump.
Old Aug 13, 2009 | 10:54 PM
MrExtreme's Avatar
Ya I saw that after you mentioned it, glad I held out for the marine pump though. it has 1000 hours on it and I only gave $300, I like friends that need money, I offered him $500 a couple months ago. Now I need a set of fuel lines.
Old Aug 14, 2009 | 11:26 AM
Lil Dog's Avatar
You will need the specific timing chart for that pump to time it properly. All the timing charts on the net are for the automotive versions and won't work. Industrial pumps have different plungers/lift ratios. Good score!
Old Aug 14, 2009 | 02:41 PM
Tate's Avatar
Go on Competition Diesel and contact Smokem. He can get you the plunger lift values for whatever you time it to. He could probably give you some good info on that pump too. Higher HP pumps aren't always more desirable. Hope it works for you though.
Old Aug 16, 2009 | 09:27 PM
MrExtreme's Avatar
Thanks I will look for proper timing info.
Thanks for the contact info, if it is not a usable pump I can always use it for a core.
HRDROKN
Mar 10, 2007 11:06 PM
pull-do
Feb 2, 2007 06:11 AM
Brendan
Dec 11, 2006 12:26 AM
West Coast
Nov 7, 2006 11:34 PM
storx
74
Sep 24, 2006 02:24 PM
