4bt conversion questions?????
Ok guys I have a 2001 dodge dakota with a blown 4.7l engine. I am going to replace it with a 4bt cummins engine. my question is can u put a p7100 pump on the 4bt does anybody know?
Thanks,
Joe
Thanks,
Joe
4 Bt
You can not put a 6bt p7100 on a 4bt as the cam that works the injector plungers has the wrong degree setting 120 deg. as compared to 90 deg. for a 4 cylinder. The good news is that bosch made some P7100 pumps for the 4bt less than 2% of total production is the 4 cylinder P7100 pump so good luck finding one. Hope this helps Bill
Yes there are P pumped 4bts around. If you have more questions on the 4bt try 4btswaps.com it's a pretty good group that focuses prmarily on those motors. Lots of swaps going on. There is someone on there that has done a 4bt swap into a dodge durango.
