P-Pump oil question
P-Pump oil question
I need a second option.
I accidentally removed the P-Pump access plug.
Oil drained out from it. I'm looking at the Dodge manaul (14-78) and it says "Diesel fuel and engine oil are used to cool the fuel injection pump."
But the picture on page (14-78) shows an "Oil Fill Plug" which is the hex bolt on the AFC housing.
So add oil? or Start engine and left it fill up?
This is normal... oil lubricates the bottom end of the pump. The oil will slowly drain back into the resivoir over time but will fill back up as soon as you start it. Start the engine and let it fill up. No worries. I doubt you accidentally removed it too, GSK install?
Thanks guys. I ended up filling the p pump since the hex bolt is easy to access. I poured in about a cup since that how much appeared to drain out.
I now have exhaust brakes and 60 lbs springs on the exhaust side. I wished I bought a set for the intake so I don't have to go back in. Cyl 5 & 6, at least I know the trick when I have to do the intake side.
GlennRMK
May 24, 2007 10:46 PM
