Oil Quick Drain Plug
Old Feb 1, 2008 | 08:07 PM
claywake222's Avatar
Just did a search on oil drain and I like the quick drain idea, but does any body know the thread size we have on are cummings? thanks.
Old Feb 1, 2008 | 08:34 PM
TIMMY22's Avatar
geno's garage has them.
Old Feb 1, 2008 | 08:58 PM
Thanks, also I like geno's garage, lots of stuff there to buy.
Old Feb 2, 2008 | 04:57 AM
NMCTD's Avatar
oil drain is 22mmX1.5 for 12valve and early 24valve
Old Feb 2, 2008 | 12:22 PM
Clayten's Avatar
DTR's Toad Wrangler
The quick drains will not let all of the oil out.
Old Feb 2, 2008 | 12:41 PM
stirpicult's Avatar
yep, they leave around a quart in there. i just installed my quick drain and plan on getting the majority out, then removing the plug to let the rest out (unless someone says this is a bad idea). might take like an extra 30 seconds.
Old Feb 5, 2008 | 08:11 PM
dozer12216's Avatar
How easy would the drain be to shear off. Anything that extends below oil pan is in harms way. You know Murphy law.
Old Feb 5, 2008 | 08:20 PM
Danderson's Avatar
The Fumoto website discounts this theory. The inlet does not extend farther up then the reinforced threaded part of the pan,thus no leftover oil. A number of members have verified this finding by removing the Fumoto and having minimal oil drainout.
Old Feb 5, 2008 | 08:33 PM
Fueling around's Avatar
I work at a transit bus OEM. We will NOT install Fumoto drain valves. If the customer wants them they are installed after delivery. Cummins does not endorse them either.
Old Feb 5, 2008 | 09:33 PM
dieselman2300's Avatar
UH WHY?
If you have a 4x4 you would have to hit the front axle considering its about 6-8" lower than the oil pan.
I have had a Fumoto on for about a year and I havent had any problems.
Also if you take the oil pan off, you will see that the threaded drain bung is higher than the bottom of the pan itself. It does have holes in it to allow for the oil to drain through.
when I first put the Fumoto on, It leaked around the gasket. I hd to drain all of the oil, and then pulled the Fumoto, and nothing major came spewing out. It was probably less than a cup.
It definately wasnt a quart.
Old Feb 5, 2008 | 09:56 PM
Originally Posted by dieselman2300
UH WHY?
Buses use a rear engine configuration called a T-drive. The oil pan is not much higher than the frame rails. We have this parameter called departure angle to hold. A Fumoto is below the departure angle.
Agree that a typical (non off road) 4x4 will not have a problem. 2wd the pan is low and any extension is a concern. I answered dozer 12216's question.
Old Feb 6, 2008 | 12:17 AM
UH WHY?
Did you know why it leaked , busted gasket?
Old Feb 6, 2008 | 12:30 AM
thewished's Avatar
Originally Posted by claywake222
... cummings?...
Sorry but I do know anyone who has a cumminGs under the hood. But I'm sure others will help with your cummins
Old Feb 6, 2008 | 12:37 AM
Tate's Avatar
http://www.genosgarage.com/prodinfo....Z-DP-22MMPL-DG
Won't have any clearance issues like the fumoto valves.
Old Feb 6, 2008 | 09:46 PM
ratsun's Avatar
Picked mine up at the local Cummins dealer, works like a charm
