Oil leak locations
Old Dec 17, 2003 | 05:23 AM
LanceD's Avatar
Oil leak locations
where is the most common place for the mighty Cummins to spring a leak? I have some oil all over the bottom half of the engine. it doesn't drip though.
thanks!
Lance
Old Dec 17, 2003 | 05:35 AM
Diesel_James's Avatar
Re:Oil leak locations
There's a good chance that it could be blow-by from the vent tube. I would check to make sure that wasn't the culprit.
Old Dec 17, 2003 | 02:46 PM
Ramflasher's Avatar
If the blowby tube isn't it, some of the 12 valves have been developing leaks in the line that runs to the vacuum pump. Check that out..
Old Dec 17, 2003 | 03:16 PM
yrusoslow2's Avatar
The front cover on mine has been leaking. It does not drip though. Plan on fixing that next week.
Old Dec 31, 2003 | 08:09 AM
sjester's Avatar
In addition to the locations already mentioned, check the gasket between the timing cover and block. Mine failed and it didn't drip just coated the suspension and oil pan after driving. Could not find the actual leak location at idle you had to run it up a little bit and watch closely because it was up high. The timing case was not damaged. Tech told me that the cover bolts had just worked loose slightly after 150k
Old Dec 31, 2003 | 11:31 AM
infidel's Avatar
What I did to keep the blowby from oil painting the bottom of my '95 is just slip a piece of 3/4'' ID hose over the stock one to extend the end a few inches from the ground. Paint the pavement not the truck. I didn't clamp the extension at all, figured if it ever got caught on anything it would pull off easily. Well it's been on there for eight years now...
Old Jan 3, 2004 | 10:06 AM
LanceD's Avatar
It looks like it might be coming from between the head and the block, is that possible? it leaks out on the passenger side, toward the rear of the engine under the manifold.
J_T
Feb 14, 2007 09:25 PM
bigragu
Jan 24, 2006 11:16 AM
LanceD
Oct 29, 2004 09:27 AM
rshelton88
Dec 2, 2002 03:52 PM
rshelton88
Nov 28, 2002 11:02 AM
