oil drip @ vent after hard throttle?
Old Dec 20, 2006 | 10:19 AM
artieb's Avatar
Hi you-all! I did the plunge and bought a 98 / 2500 / quad cab / 4X4 / 12 valve / 53 block / automatic... A Georgia truck no rust... built trans w billet converter and warranty until May 2007! The turbo's vacuums bypass has been disabled. And as far as I can tell no mods by paint on bolts, nuts, IP. It pulls pretty good. What the problem is that oil will drip out the vent after a hard throttle, not much.... I know the dipstick shows about 1/4 to 1/2" overfill? Just wondering, as I have read threads stating 5 quarts in 50 miles, hard pulling from the vent. I am looking at some antifreeze leaks, too! Another thread, if I can't figure it out... Thanks, and wish me luck! Artie
Old Dec 20, 2006 | 05:22 PM
clutch1's Avatar
Where did you hear 5 quarts in 50 miles? There should be nothing but a vapor coming from breather and the occasional single drip if any.
Old Dec 20, 2006 | 10:09 PM
TIMMY22's Avatar
ahhhh,
looks like you've got one of those early "53's" in a 12V.
If you're loosing oil out the breather tube, infidel mentions to check for vacumn pump leak into the crankcase like a compressor.
otherwise, sounds like you have excessive blow-by (rings). do some compression tests.
Old Dec 21, 2006 | 11:52 AM
artieb's Avatar
Cool
Thanks, I was wondering if being overfilled, and more crankcase pressure from the wastegate would cause this condition? I'll " GIT ER DONE"! Thanks, Artie
BearKiller
Jul 11, 2022 02:43 PM
dslpwr81
28
Jan 26, 2009 09:08 PM
b4wheeler
Apr 18, 2007 03:54 PM
BearKiller
Feb 15, 2007 10:39 PM
al*gray
14
Jan 27, 2004 06:03 PM
