NV4500 power vs. lifespan
Old Jun 15, 2009 | 07:32 AM
12ValverDave's Avatar
Any ideas how much power a nv4500 can handle, and does these elevated power level drastically reduce the service life of these?
Dave
Old Jun 15, 2009 | 10:58 AM
patdaly's Avatar
So far I have seen more U joints and driveshafts, frames etc. dying before a good NV4500 does........
Old Jun 15, 2009 | 12:05 PM
infidel's Avatar
The 4500 can handle lots of power.
Problem is parts for them are getting harder and harder to come by.
Old Jun 15, 2009 | 03:08 PM
Whats the worse thing for them? Lugging them right?
Old Jun 15, 2009 | 05:34 PM
GAmes's Avatar
My original trans lasted 160k, I had added the plate at about 98k. Since then I have had only two transmissions go over 100k, and have had major failures with as little as 7k. Average 100k for a rebuild. They were designed for about 450 lbs of TQ, my 97 engine stock was rated at 440 at the flywheel. After I was able to dyno 611 at the wheels which was, I'm guessing, 700+ at the flywheel, longetivity decreased dramatically. A short answer to "does these elevated power level drastically reduce the service life of these?" is YES!
Old Jun 16, 2009 | 01:09 AM
Tate's Avatar
What did you break, and were you towing a lot with it?
Old Jun 16, 2009 | 11:23 PM
GAmes's Avatar
Yes I tow a lot, like 70 to 75% of the miles, sometimes pretty heavy. Usually the gears on the countershaft go. If I press on in 4th gear, and I have a couple times, every gear in there fails. I believe, but do not know for sure, that towing in 5th wears the countershaft bearings bad enough to permit the gears to impact other stationary gears, and that gets the ball rolling. At least that is what three of my total failures sounded like. A lot of clicking, growing louder in intensity until all h*** broke loose.
dshind
Oct 11, 2007 10:00 AM
phabib
28
Jul 12, 2007 10:21 AM
Jim5870
Apr 11, 2005 10:12 AM
TDIwyse
33
Dec 25, 2004 02:00 PM
Dodgezilla
13
Jan 10, 2003 11:44 PM
