Nv4500
The bellhousing is not part of the NV4500 - the dual bolt patterns allow fitup to GM and Ford and Dodge bellhousings.
HD versions have provisions for power takeoff attachment - several vendors offer 1.3750" input shafts for the 13" clutch
The NV5600 bellhousing is the front bulkhead for the gearbox, with only the Dodge pattern with hi-mounted starter for the Cummins.
Finally Found one
After 3 weeks of searching I finally found one in a local salavage yard. They are pulling it out today and Monday and I will pick it up on tuesday and so begins the auto manual swapout.
NV4500s from 2000 and earlier Dodge 4WD trucks with gas V8s had 23 spline output shafts vs the 29 spline output shafts in the NV4500HD models found in 4WD trucks with the diesel and V10 engines. After 2000 Dodge used only the 29 spline NV4500HD.
whiteknight
Dec 27, 2002 06:28 PM
Hummin Cummins
Dec 25, 2002 12:29 AM
