no power when cold
Old Nov 16, 2005 | 01:14 PM
skeeter's Avatar
no power when cold
95 dodge 12 valve would the fuel shut off solenoid cause you to have no power if it was real bad. truck has no throttle response when cold but after it warms up runs fine all filters are new and we replace the solinoid because it fell apart in 3 peices
Old Nov 16, 2005 | 03:13 PM
apache's Avatar
If its not adjusted right it would be screwed up all the time me thinks.Do you have guages? hows boost look? Does it run OK on start up? smoke etc?
Old Nov 16, 2005 | 04:48 PM
skeeter's Avatar
no power when cold
no gauges smokes alot on start up runs ok on start up you just cant go untill
it warms up if you try to floor it in neutral it misses alittle and will not rev up past 1500 to 2000 but once warms up seems to run ok
Old Nov 16, 2005 | 06:30 PM
infidel's Avatar
Your fuel pressure could be too low.
You can make a set up to check the pressure or for about the same amount of money replace the overflow valve.
You won't find a better price than here
Precision Diesel Injection and Turbo Inc.
Marty Tompkins
888-734-7349
$35 + $7 shipping and handling.
Old Nov 17, 2005 | 08:36 AM
MnTom's Avatar
Those symptoms are also indicative of retarded timing.
Old Mar 13, 2008 | 07:18 AM
whiteknight's Avatar
my brothers truck is doing same thing(96") it misses bad for about 5-10 minutes till you blow it out he says! then it is fine people is telling him sounds like injectors (they work better when they get warm!loosin up some)
keep us posted.
Old Mar 13, 2008 | 10:51 AM
Lil Dog's Avatar
I would also agree if hasn't been checked in a while.
Old Apr 7, 2008 | 10:51 PM
West Coast's Avatar
My truck is doing the exact same thing..... Takes 10 minutes to warm up. Will spit and sputter until it gets warm. And TONS of white smoke. I noticed tonight that my fuel shut solenoid is not lifting when I start it. And I think my grid heaters and grid solenoids are not working either....
Old Apr 8, 2008 | 11:23 AM
94 12valve's Avatar
I took my heater out and when its below 50* outside it sputters for about 30 sec then settles right out above 50* it doesnt sputter at all.
Hydrauk
16
May 7, 2008 02:58 PM
akhunter68
Oct 31, 2006 05:07 PM
joel
Jan 22, 2005 08:59 PM
BEHRMAN
Dec 24, 2004 11:05 PM
wings
Nov 8, 2004 05:32 PM
