need a rebuild TIME FOR THE ULTIMATE ENGINE!!!
Old Jul 24, 2007 | 01:19 AM
swampthang's Avatar
ok i bought a complete 94 5.9 and it is blowing oil bad which is fine for me as i wanted a cheap complete p-pumed engine to build up for my twin turbo project i will be towing with this engine all most all of the time so it will need to be built to do that now i would like to "over build" this engine for my truck so i dont have to worrie about it later it will be going into my 1993/81/06 custom 6x6 crew cab i am building i am using the mercedes g56 6 speed trans a 205 t-case and a gear vendors for the rest of the drive train
so where is a good place to get a decent priced engine kit (maybe oversized)
where is a good place to get the head fire ringed or o ringed
where is a good palce to get a set of head studs
anything else i should do ??
as said i want to "OVER BUILD" this engine and do it right the first time i have around a 4k budget to build the engine 2k for the custom twin turbo set up
Old Jul 24, 2007 | 11:28 AM
LAWN GUY's Avatar
as far as studs go use arp i dont have a set yet but have friends that are running them.
Old Jul 24, 2007 | 11:53 AM
Need95-00CTD's Avatar
For 4k your on a tight budget, headwork alone for the o-rings will be at least 750... over 1200 for fire rings, and you'll need to pull the block. Marine Gasket, Studs, Cam, Injectors, DV's, Plate, Intake, Air Horn, Manifold, Pistons (if you think you need them), KDP, 215 Pump, Timing, Exhaust...etc. etc. Your looking at a mild build with that budget, nothing wrong with that for towing, but its certainly not the "Ultimate" engine...your getting well into 5 figures for that.
Old Jul 24, 2007 | 01:54 PM
LOGAN's Avatar
Muted User
to do everything for the "ultimate" engine, you better have 20K to burn for everything you need.
Old Jul 24, 2007 | 03:16 PM
kas83's Avatar
Or be able to shop very thrifty. If you can do all the work yourself, ie machining, assembly and so on, you might be able to stretch that dollar amount, but if you need a place to do the work for you, kiss that money good bye.
I say if you're gonna have the head worked on, why not get it ported and polished right away too. The extra flow is going to help all around.
Old Jul 24, 2007 | 03:23 PM
swampthang's Avatar
well i said the untimate engine i should have said for towing i want the unlimate engine for towing with a set of twins i would "like" 1,300 ft lb tq on just my boi diesel and propane injection i can build the twins my self so i need the head done the injection pump tweaked/rebuilt new injectors gaskets and i want all new rings and berrings in the engione i can reuse the pistons,rods,crank as far as i know i have not torn the engine down yet to see but if i do need new pistons i will go over sized
JC
Old Jul 24, 2007 | 04:39 PM
bigyellowiron's Avatar
I sent you a PM.
Old Jul 24, 2007 | 05:10 PM
tony597fitter's Avatar
You should be able to get o-rings on the head for less than $400.
Check out http://www.performancedieselwarehouse.com/ they can get you setup wiyh a new head and orings with 60# springs for under $1200.
Also the stock bottom end is good for alot of HP and TQ. There are alot of guys running well over 700 hp on the stock bottom end.
A camshaft is around $750.
Injectors, anywhere from $500-$1000
ARP studs are anywhere from $400-$450
Laser cut DVs are around $220
Marine gasket around $140-$160
Everything else is minor stuff.
If the internals of the engine look good, do the head and studs. With the twins you could easily be in the 600-700 hp range.
Old Jul 24, 2007 | 10:31 PM
swampthang's Avatar
Originally Posted by bigyellowiron
I sent you a PM.
sent ya one back
JC
Old Jul 25, 2007 | 12:15 AM
swampthang's Avatar
ok got some more info on the engine tonight it has a 185 pump on it the engine came out of a 1994 standard truck am i good with just building the 185 pump some or should i get a 215 pump? i can build a 185 up to 215 specs correct ??
JC
also i see there is gov spring kits all the way up to 5k what would that do ? i know i would have to have 60 spring in the head what else will the rest of the factory accesories hold up to 5,000 rpm ?? i can free rev (rear end up in the air no load on it) my 91 to 4,200 now i did that to check for vibrations after the nv4500 install in it
csa
Apr 2, 2011 09:14 AM
Johnny V
Oct 22, 2007 09:56 PM
kas83
Jan 11, 2007 03:32 PM
