need help with timing ??? long
Old May 24, 2007 | 12:33 PM
oldblues's Avatar
Question need help with timing ??? long
hi
well i was giong to bump the timing a little while doing the kdp fix and this is what i found !
after verifing tdc a few times i indacated the pump lift and found it to be .205" at tdc ???
well now what is my timing at now ??? cpl is 2174 1998
i was going to set it at 16 deg = .193" my chart does not go higher than 16 , does anyone have a chart that does ?
if i back it off how will this affect it ?
fuel economey is a priority also i like some power but not a major concern .
what should timing be set at to best drive localy mostly 25-55 mph?
what should it be set st to drive hiways 70 mph for best economey ?
best i have got so far is 21.4 mpg but i have no idea what condition filter is in as i have only had truck a few mounths and did not drive it much as i was wanting to do the kdp first . now i will not be scared to drive it .
plan to do the filter as soon as i get it back to gether
thank you !
Old May 24, 2007 | 02:18 PM
Lil Dog's Avatar
Here is a timing chart that shows timing up to and including 16°..
Dodgeram.org timing chart
The timing you have is pretty advanced, like over 17° which to me seems pretty high IMHO.. Great for racing over 4K Rpm but not much for a daily driver. I would roll it back to 4.9 MM or 0.193" and see how it operates.
Old May 26, 2007 | 10:00 AM
fschiola's Avatar
By my caculations your at 17.5* right now. If you advance any more you'll probably be doing a search on how to change head gaskets.
Old May 26, 2007 | 09:24 PM
JKM's Avatar
JKM
I have been running 18* on a 12 year old headgasket since september, no problems yet *knock on wood*.
ilmbg
Nov 6, 2016 03:57 PM
toy4xchris
May 21, 2007 03:29 PM
jkravito
Oct 13, 2006 05:16 AM
csramsey640
May 1, 2006 08:02 AM
04ctd
Feb 9, 2006 12:04 AM
