Make It SHUT UP!
Old Feb 12, 2007 | 11:15 PM
Mopar440_6's Avatar
Angry Make It SHUT UP!
About three weeks ago I noticed that the serpentine belt on my truck was badly damaged. Guessing that a bad tensioner had ruined the belt I checked it. Being the stock tensioner (140K miles) it had some play in it but not a whole lot.
So I replaced the belt and tensioner with NAPA replacements. The truck was great for the past two-three weeks but now it as started squeeking/squeeling. It does this anytime the truck is running. It doesn't look like the belt is slipping over any of the pulleys but the squeek is driving me insane!
Did I get a bad tensioner or did I install something wrong? I just want the truck to quiet back down. I'm about ready to put the original tensioner back on!!!
Old Feb 13, 2007 | 12:12 AM
Need95-00CTD's Avatar
Check your pulley alignment and buy a new belt...if its squeeling, your chewing the new one. BTW, get yourself a GatorBack belt from Goodyear, its worth the extra few dollars, trust me.
Old Feb 13, 2007 | 12:45 AM
Common's Avatar
Maybe the waterpump is starting to lock up a little...
Old Feb 13, 2007 | 12:16 PM
woodrat's Avatar
On mine the alternator was loose and hanging at just enough of an angle to make the belt ride against the tensioner. I replaced the belt, tensioner and fixed the alternator and that was the end of the noise.
Old Feb 13, 2007 | 06:35 PM
orgsrt4's Avatar
an easy way to tell is to spray some brake parts cleaner on the belt it goes away is the belt if not its a pully
Old Feb 13, 2007 | 08:45 PM
bgilbert's Avatar
AC compressor going bad? Are you running an AC or nonAC belt? Is the squeeling when the truck's running or when shutting off?
dkimmel
Jan 3, 2011 10:54 PM
randyswelding
Feb 9, 2009 10:40 PM
dsl-man
Mar 20, 2003 02:57 AM
Grant.G
Nov 11, 2002 03:57 PM
rattle_rattle
Nov 11, 2002 02:40 PM
