Leaking valve covers
Old Feb 19, 2012 | 07:14 PM
esgdakota's Avatar
Hey everyone
Pulled the valve covers off and painted them a couple months ago and installed new gaskets the rubber ones and now I am having problems with them leaking! The cover bolts are bottomed out and tight! Any thoughts on why? could the covers be bent from being tightined to much?
Thanks
Eric
Old Feb 19, 2012 | 07:33 PM
caper's Avatar
I had the same proble with a couple of them , you gota make sure they are on correctly and are not folded under the cover , double check that I bet its your problem.
Old Feb 19, 2012 | 10:37 PM
esgdakota's Avatar
checked them all already pulled them off and even reset them still no differance!
Old Feb 20, 2012 | 08:44 AM
patdaly's Avatar
Were they genuine Cummins? I have heard of sporadic reports of aftermarket gaskets not lasting.
Old Feb 20, 2012 | 09:56 AM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Wish I could remember where I got mine...They where black gaskets that I installed 6 years ago...I removed them about 5 times and never had them leak yet..
Old Feb 20, 2012 | 03:15 PM
TheMrAMack's Avatar
Sounds like to me that you have a bad gasket. If I were you, I would replace it and try a little black/ blue glue and see if that helps seal things up. I am new to this however, there are many people on here far more qualified than I am.
Old Feb 20, 2012 | 06:48 PM
esgdakota's Avatar
No they are not cummins gaskets but like I said I just replaced them they are not but 1k miles on them! I guess I will try to get some cummins gaskets for it unless some one else has a better idea?
dieselcarpenter
Mar 29, 2014 09:21 AM
Mixer Man
Aug 17, 2004 10:36 AM
wick
Mar 9, 2003 10:51 AM
Voss
Feb 11, 2003 12:25 AM
BlackSheep
Nov 22, 2002 04:42 PM
