Leaking trans. hose
Old Feb 25, 2006 | 04:51 PM
John Faughn's Avatar
Leaking trans. hose
I've got a hose on the trans. cooling lines that is located off one line on pass. side under exhaust man. , the hose part is 6-8" of hose with fittings on either end , its leaking and a while back I thought I heard that some guys were replacing with hydrolic hose ,
I'ld like to get sizes for the fittings so that I can take out old and just put in new ,making one ,
Its my only transpretation so I need to go to town get parts and make at home .
Thanks.
Old Feb 25, 2006 | 05:19 PM
fordsux8269's Avatar
Just be extra careful drivin around with it like that. Mine was dripping for a day then I took a buddy of mine out for a ride and when I got back it was pouring out.
Old Feb 25, 2006 | 05:45 PM
When I saw the like , I went and bought a case of ATF , both to keep the level up and refill when I get hose replaced .
Old Apr 9, 2006 | 09:20 AM
rockbarn's Avatar
transmission hose
The hose you described with 2 fittings,it is a check valve for the transmission,which goes to a transmission water cooled oil cooler..junk it and have a new one made.Dodge has a kit to change the lines, which go to that cooler for a 253.00 price tag.You can cut the 2 lines, flare them and ,change the 2 oil cooler fittings.The transmission fittings made with the cheesey plastic ends that you squeeze together are made for quick assembly when the truck was being built.There are replacement transmission fittings which have a steel insert that are on the transmission,which work quite well.But to remove them you need a tool to relax the insert.Dorman makes the replacement fitting.
atc250r
Jan 31, 2007 08:14 PM
twvette
Dec 6, 2006 11:53 AM
george7941
Aug 10, 2005 07:06 PM
ET RAM
Feb 28, 2003 08:24 PM
