KDP do it yourself
Old Jun 22, 2010 | 07:18 PM
KKRRSS's Avatar
KDP do it yourself
Okay, I ordered the TFT kit and I'm wondering how hard it is to do it myself?
I'm a 'change my own oil, replace a starter' kind of guy. Own my own tools, no specialty tools though.
KRS
Old Jun 22, 2010 | 07:54 PM
Tate's Avatar
No special tools needed. A 10mm wrench and socket will do most of the work for you. Hammer and a punch to change the seal, and thats about all you need.
Old Jun 22, 2010 | 08:14 PM
RoadDiesel's Avatar
..as long as your "In There" ...I'd replaced the water pump, Idle bearings,etc....if you haven't already..
Old Jun 22, 2010 | 10:01 PM
roughstock's Avatar
That is what I did, and fan clutch. All mine had 290,000 miles and were original, so i figured better now that on side of road.
Old Jun 22, 2010 | 10:56 PM
KKRRSS's Avatar
By idle bearings, do you mean the belt tensioner? If not, I don't know what you're talking about.
Old Jun 22, 2010 | 11:04 PM
KKRRSS's Avatar
Is the water pump really only $50???
I'm looking at Genos website.
Old Jun 23, 2010 | 07:45 AM
patdaly's Avatar
LOL, yep.
Don't celebrate just yet, there are more things with prices to make you wince than gifts like a 50 dollar WP.......
Old Jun 23, 2010 | 08:03 AM
blackimpala's Avatar
If you are removing the fan, remember that it has left hand threads.
Floyd
Old Jun 23, 2010 | 08:37 AM
KKRRSS's Avatar
I've read the TFT instructions about 10 times, went out and found the tools (you're right, it's not many) and I think I'm going to do it when the kit gets here.
The kit didn't come with a gear cover gasket, should I go to the dealer and get one instead of using only RTV to make a new one? I don't want oil leaks.
KRS
Old Jun 23, 2010 | 09:45 AM
infidel's Avatar
I'm old school who only knew gaskets for forty years.
RTV has been a godsend, works just as well, is less expensive and easier.
I rarely use gaskets now unless I have to.
Old Jun 23, 2010 | 09:53 AM
Greguw's Avatar
You may want to re-loctite the timing case bolts and cam retaining bolts , I found them loose on a few motors I have done .
Old Jun 23, 2010 | 02:26 PM
KKRRSS's Avatar
looking for torque on the other bolts....
Old Jun 23, 2010 | 10:06 PM
RoadDiesel's Avatar
yes... that is what I meant....
Old Jun 24, 2010 | 08:43 AM
KKRRSS's Avatar
Okay, the Haynes manual (I know I know.... the FSM is on the way) says to install the crank seal after the cover is loosely bolted up; the TFT instructions say to install the crank seal into the cover while it's on the bench.
Any thoughts, advice?
KRS
Old Jun 24, 2010 | 09:17 AM
Silver Ram's Avatar
do it on the bench
wilderness
15
Nov 6, 2013 08:47 AM
Smokin96_12v
Oct 12, 2009 07:39 AM
Common
Jul 4, 2006 09:59 AM
RHC
Mar 25, 2003 06:03 PM
PADZZ
Oct 8, 2002 10:36 PM
