Intercooler Boot Test
I saw pictures of a fixture someone made out of PVC pipe to test the connections on the intercooler boots for leaks. Can someone send me a link tio the post?
I have a intake that is all sooted up from the now gone EGR valve. The line that goes to the AFC is clogged from the soot and I want to try and blow it out with compressed air. If I pressurize my intake and disconnect the line at the AFC it may remove the obstruction. If it doesn't I'll cap the existing line and run a line from one of the 1/8" NPT holes that are in the 49 state air horn that I bought.
Thanks,
Bob
Thanks,
Bob
Like this?
PVC pipe is 4" with a port for a tire chuck and gauge tapped in the cap.
Hose clamp rubber coupler that attaches to turbo is a 4"id X 4"od, $10 from Home Depot.
Do not pressurize over 40 psi, the tester could come flying off like a missile
Now I have to find a short lenth of 4" PVC pipe.
I have a small pressure regulator that I'll use with my compressor. How do you keep the pressure from leaking out any open intake valves?
I have a big compressor with a 200 gallon reciver tank. I should be able to keep up.
How much pressure do you introduce into the manifold? It should be able to handle 30 psi, no?
95black2615
Oct 8, 2008 03:34 PM
