intake heaters
Old Feb 15, 2009 | 02:02 PM
TRCM's Avatar
intake heaters
should both heaters come on all the time, or just one until it is colder outside ?
both relays cycle when testing them, but when they are connected up in the normal circuit, only 1 comes on (and I don't think it was until I cycled it using jumpers)
1 relay doesn't seem to be cycling using it's trigger wires, but if I move the trigger wires from the other relay, it does.
Old Feb 15, 2009 | 03:06 PM
TRCM's Avatar
OK...here's what I have right now
air temp sensor is bad...reads open
I have a 97, so the 12v trigger wires are both bk/gr, and the trigger wires for the ground from the pcm are yl/bk & or/bk.
one of the gr/bk wires has 12v to it, the other doesn't.
neither of the trigger wires from the pcm show as a ground when the key is on. this may be due to the bad air temp sensor.
Why would I have 12v to only 1 of the gr/bk trigger wires ?
Old Feb 15, 2009 | 03:41 PM
infidel's Avatar
This may help http://dodgeram.org/tech/dsl/trouble...niford_htr.htm
Old Feb 15, 2009 | 03:51 PM
TRCM's Avatar
already looked thru that link
it says the wait to start light won't come on above 60 deg, and mine has always come on for more than 2 sec
anyway...1 or the ford relays I have now is acting weird, so I just ordered the relays and a new air tmp seonsor from rockauto.
when they get here, I'll try to figure this out more...heck, I may just put a manual switch in
foxtrot
May 9, 2011 04:24 AM
sleeperman
Jan 29, 2009 12:37 PM
toypar
Nov 19, 2006 09:10 PM
TRCM
Nov 6, 2005 08:33 PM
wadem
Oct 28, 2004 10:18 PM
