? on installing fuel gauge
Old May 8, 2004 | 11:39 PM
matador's Avatar
I bought a 0 to 15 lb mechanical fuel pressure gauge and was going to install it but wondered where the rest of you have tapped into the fuel line.
I was thinking of cutting a chunk out of the metel line from the fuel filter to the P7100 pump work. I was just going to splice in a brass T fitting and use 1/4 I.D. rubber fuel line hose.
I heard some say they used a length of rubber grease gun hose and ran this into the cab. Is the regular rubber fuel line hose that I was thinking of using too soft or expand too much?
What is the most pressure I would see?
Thanks guys,
Matador
Old May 8, 2004 | 11:55 PM
infidel's Avatar
First of all your 15 gauge won't even read the minimum FP on a 12 valve, you need at the very least a 40 psi gauge, 60 psi is best.
Easy way to tap in is to remove the injection pump inlet line banjo bolt and tap a 1/8'' port in the top of it. Teeing into the fuel line sounds like a leak waiting to happen.
You will need to use a gauge snubber or needle valve shut almost all the way right after the banjo bolt or the pressure will pulsate so badly that the gauge will be unreadable.
I use regular ol' boost gauge 1/8'' tubing from the needle valve to the gauge in the cab. Push it though a larger size tubing (1/4'') to protect against sharp edges and kinks.
Needle valve installed in banjo bolt
Old May 9, 2004 | 12:00 AM
matador's Avatar
What is the maximum pressure I should see? What does yours say at idle and then a full throttle?
Thanks,
Matador
Old May 9, 2004 | 12:07 AM
infidel's Avatar
Mine reads about 22 psi at idle and a max of 38 psi at full throttle.
Old May 9, 2004 | 12:09 AM
matador's Avatar
I see I need a different gauge.
Matador
Duck assassin
Feb 20, 2013 04:09 PM
mstep3
Aug 30, 2009 07:27 AM
kdbvulcan
Dec 9, 2008 10:58 AM
65pacecar
25
Dec 1, 2007 08:45 AM
na4now
14
Nov 21, 2007 07:08 PM
