Idling Problem
Old Oct 14, 2004 | 11:57 PM
CanuckCTD's Avatar
Idling Problem
Hey Guys,
I was driving home tonight and noticed that my truck was idling too high. When I pulled up to a light I could really hear it and when I shift it doesn't sound right. It seems like the throtttle linkage could be jammed as it doesn't idle down like it should. Any comments on what to look for to fix this??? I know I have been vague but any suggestions on what it could be would be appreciated. I did have the throttle linkage recall done last month so I'm wondering if it could be the problem.
Old Oct 15, 2004 | 06:36 AM
Smokee's Avatar
I am guessing that the throttle cable is fraying and sticking. This is a common problem, although usually the cable stretches and the idle is too low.
Another possibility is that you have a small air leak. Does the truck start more slowly than usual?
Old Oct 15, 2004 | 08:43 AM
kandgo's Avatar
Check down on the back side of the pump for the throttle linkage arms, the set nuts on the adjustable arm could have came loose and the adjustable arm will turn or spin and will not let the injector pump go to idle. Goodluck,,Ricck
Old Oct 17, 2004 | 07:23 PM
torquefan's Avatar
Take it back to where the recall was done, it should have included a new cable, return spring, and rod ends.
twropn
Dec 8, 2007 12:25 AM
scottmn1
Jul 28, 2007 05:49 PM
Wet1
Jan 29, 2007 02:26 PM
jp39bfd
May 15, 2006 06:34 PM
silverbullet02
Sep 7, 2005 04:49 PM
