I have solid axle swap questions
Old Dec 10, 2008 | 08:47 PM
mach2's Avatar
Hey guys, I might be trading my dad for a 93 gmc 1 ton 2wd crew cab dually and if i get the truck (within a couple of months hopefully) im goin to try my luck at repowering it with a cummins and would some day like to be able to do a solid axle swap. Thats where i become lost, I have no idea what im talking about when it comes to doing a axle swap. Could you guys hep me out??
Thanks, Bryce
Old Dec 10, 2008 | 09:04 PM
greg@Lockitup's Avatar
http://www.offroadunlimited.com/orus...?idCategory=19
Old Dec 10, 2008 | 09:05 PM
oops.. this one instead..
http://www.offroadunlimited.com/orus...?idCategory=18
Old Dec 11, 2008 | 02:39 AM
srv8800's Avatar
if you're planning on playin hard, get a gm dana 60. if it's just to have a big truck, get a gm dana 44. you can get them in 8 lug from a 3/4 ton truck or swap a 1/2 ton axle to 8 lug. reason is a d44 can be had for next to nothing. these days, a d60 can cost almost a grand.
now that you have an axle, you need to mount it. definetly go with leaf springs since they are simple and easy to set up. no offense, but it doesn't sound like you need to be setting up 4links. www.diy4x.com has some good spring hangers that you can bolt right on.
steering is the last piece. definetly go with a crossover setup. www.offroaddesign.com has good stuff but are a little over priced. www.sky-manufacturing.com is another good one. good luck and post pics.
mark
Old Dec 11, 2008 | 04:14 AM
Tate's Avatar
Depending on which drivetrain you go with will determine what axle you want. If you go with a first gen dodge setup with a passenger drop t-case, a GM or old dodge axle is what you will want. Those are all low pinion king pin axles. If you go with a 2nd gen drivetrain with a drivers drop t-case, you'll want either a ford (preferred) or a second gen dodge axle. Ford is a high pinion (better driveshaft angles), king pin up until 91, balljoint to 97. Either manual or vacuum lockouts, and servicable wheel bearings. Newer dodge is CAD, balljoint and unit bearings, so I wouldn't even look for one.
Old Dec 11, 2008 | 08:56 AM
srv8800's Avatar
for a swap like that, i wouldn't even bother with the dodge tcase. use a np205 instead. since that's a ps drop tcase, you can use a gm d60.
good luck, i gotta go take a final.
mark
Old Dec 11, 2008 | 09:12 AM
98whitelightnin's Avatar
I agree with Tate, If you can find a ford D60 its reverse rotation(high pinion) for strength and will give you the driverside output you will want plus lockout hubs. You can get a ford np205 transfer case or any newer transfer case as they mostly all are drivers side outputs. I dont think the ford D60 is set up for coil springs like the ford D44 is but it would be easier to do leaf springs.
Old Dec 11, 2008 | 10:35 AM
mach2's Avatar
Thanks for the input guys. I'll probably go with a 1st gen motor for ease of swap and the fact that a good motor can be found for around 2grand.
Old Dec 11, 2008 | 06:40 PM
Tate's Avatar
mark
NV241's hold up under power in our trucks, see no reason to ditch them to go to the 205 with a worse low range than the 241. And he could always use a Ford 205 anyway. His truck is a driver drop t-case as it sits now, so I'd imagine it would be easier to keep the same style t-case in it.
Old Dec 12, 2008 | 01:37 PM
mach2's Avatar
what bout drive shafts??
Old Dec 12, 2008 | 03:00 PM
srv8800's Avatar
he's starting with a 2wd. in reality, there's 300 different combinations he could do and all would work great. all of the solid axle swap "kits" are going to use a gm axle. a 241 or a ford 205 and a ford d60 would be fine and so would a gm 205 and 60.
for driveshafts, it depends on what tcase you choose. a 241 has a slip yoke rear output. i would swap it to a fixed yoke output with a 1350 yoke to match your 14blt rear axle. the front output on whatever tcase you get will probrably have a cv flange. if you don't get the front driveshaft with the tcase, you'll have to either find one somewhere else or buy the cv joint from a driveshaft shop. any driveshaft shop can make these shafts for you.
Old Dec 12, 2008 | 07:26 PM
97dodge12v's Avatar
this is mine, i did all the work, feel free to ask questions, i went with the skys off road kit, and it work out just fine.
Old Dec 13, 2008 | 12:05 AM
Yellow Yota's Avatar
Attachment 25161
Attachment 25162
Attachment 25163
Looks nice! I always like to see people using stuff that Sky makes. His parts are just about as beefcake as can be. Prices are pretty good as well. He definitely stands behind his products as good as anyone.
But hey. What do I know? I just left his shop an hour ago!
v8440
15
Aug 11, 2024 06:17 AM
moTthediesel
Oct 6, 2014 12:44 PM
Yukon 400
Feb 13, 2008 11:21 PM
rjm022
Nov 17, 2005 07:30 PM
