I have a BIG pump!
Old Aug 24, 2005 | 08:17 PM
doubleclick's Avatar
Question I have a BIG pump!
Well, big for me. My truck should have the 160hp pump, but my CPL didn't match the pump. So I called Piers Diesel, turns out, from the numbers on my pump, its a 175hp pump. From what I could tell, everything was stock. Thats okay, I'm not complaining, I could use a few extra horses
Old Aug 24, 2005 | 09:06 PM
blackdiesel's Avatar
Registered
the more the better, right? (haha in most cases...)
Old Aug 24, 2005 | 10:18 PM
DieselDaze's Avatar
I had to have my pump replaced recently.
I have all my work done by the local Cummins shop, the've come to know me well.
When it came time to replace my pump (Stock was the 160), they replaced it with a Re-con Cummins 175 as well.
Rich.
Old Aug 25, 2005 | 07:39 AM
signature600's Avatar
Shoulda went with a 215 there Rich!!
Mo is Betta
Chris
Old Aug 25, 2005 | 07:57 AM
DieselDaze's Avatar
Mo is Betta
Chris
Well, that may be true in less your referring to the bill that comes along with a 215!
The 175 pump with labor was just a bit over $2000.00 (I also had them replace the fuel shut-off solenoid, change oil, fuel filter, and replace the rubber fuel return line).
Anyway, the 175 pump listed somewhere around $1500 (I dont recall the exact price) and the 215 pump listed around $2200.
I understand that the replacement of the 160 pump with the 175 (For the automatic trucks) is common based on what the automatics are built to handle.
Cummins doesnt want to be responsible for smoking transmissions.
Rich.
Old Aug 25, 2005 | 04:46 PM
I was thinking maybe someone screwed up and put the 175 pump on mine thinking it was going to be a standard. Who cares, it actually satisfied my bomb craving for like, 6 hours!
Old Aug 25, 2005 | 05:09 PM
Yeah, probably...that's why I bought a used one that tested out good for $900.
Now just to find time to change them
Chris
Old Aug 25, 2005 | 06:25 PM
Did you get a 215 or a 175? There is a cummins rebuilt 215 pump on a 5.9 in our shop, I'm trying to see what it would take to swap. My pump puts out a whole lot more than 215 anyway. Whatever bus it goes into would run nice
JSCumms2000
20
May 6, 2007 02:14 PM
Mexstan
Sep 16, 2006 05:29 PM
boiler-rat
Jan 16, 2006 03:11 PM
Dieseldude4x4
Oct 17, 2004 11:07 PM
Shaders 24v
Aug 11, 2003 10:18 AM
