I HATE my open differential
Old Dec 24, 2010 | 12:12 PM
runningbird's Avatar
I hate this rear end! it is on my 96 12v 2500 4x4. please help me with my options. I tow quite a bit, both a horse trailer and a equipment trailer. even in loose soil like my home I can get stuck in 2wd. if anyone could include approximate prices with their opinions I would be grateful!
thanks for the help and idea's!
Old Dec 24, 2010 | 12:31 PM
cj360trider's Avatar
DANA 70 or 80?
http://cgi.ebay.com/ebaymotors/DANA-...Q5fAccessories
figure out ur spline 32 or 35. these units replace ur spider gears in your open diff carrier housing. ill be getting one as soon as i can afford it
Old Dec 24, 2010 | 12:35 PM
it is a dana 80. I have a 5spd. do I need to pull the drive shaft to count the splines? and thanks for the reply.
Old Dec 24, 2010 | 12:54 PM
see if you can find one of these units for an 80 i posted for 70. then you will need to pull an axle shaft and count splines
Old Dec 24, 2010 | 01:03 PM
Hodge's Avatar
Part of the problem is the heavy front end of the truck. Even if you put a locker in the back, it won't solve all of your problems. Sometimes you will just have to use 4WD.
Old Dec 24, 2010 | 02:09 PM
Tate's Avatar
Dodge D80's are 35 spline.
Old Dec 24, 2010 | 02:21 PM
banks twinram's Avatar
Dont buy a powertrax lockrite!!! Its a waste of money i bought one and it lasted two weeks! Get a stock posi from a different truck i actually have one for a dana 70 pm me if interested oru an get one from a junkyard
Old Dec 24, 2010 | 03:44 PM
thanks for the help. Our 98 4x4 has a stock posi and it works great. after 250k it still chirps the tires going around a corner.
are the posi's for a 80 and 70 interchangeable?
Re: junkyards. I have been to many in the Phoenix area and have always come up empty.
Old Dec 27, 2010 | 11:24 AM
Midnite's Avatar
They are not interchangeable. With a Dana 80, I had a shop install a Trac-Loc limited slip a couple of years ago. Unfortunately they set it up so it wasn't all that tight, and it slips quite a bit. A different shop installed a Powr-Loc in the D70 in my 1992 truck, and set it up tight enough to chirp the tires in a tight corner, and it was wonderful how much traction I had.
Runningbird, are you sure you have a D80? I thought that the early 2nd gens all had D70s, even with the manual transmissions. If you have a 70, I'd highly recommend a Powr-Loc, and tell the installer you want it set up as stiff as possible. If you truly have an 80, then go with a Trac-Loc and tell them the same thing.
Old Dec 27, 2010 | 07:12 PM
Midnite, thanks for the help.
the underhood sticker states dana 80 so I am going with that. our 2wd 94 truck also has a dana 80.
Old Dec 27, 2010 | 09:30 PM
MarkT's Avatar
Mine also has a D80 35 spline open. I also been thinking about a LS. I would like to have the clutch pack style but my local dealer wants $2900 for just the parts. The torsen gear type are about $600 and I am very tempted to go that route.
Old Dec 27, 2010 | 11:54 PM
Midnite's Avatar
Wow, $2900 is beyond ridiculous! You should be able to pick up one from a place like quad4x4.com for $500 - 600, shipped.
Old Dec 28, 2010 | 07:57 AM
patdaly's Avatar
Check out Ebay, they usually have some........ You will need to know if 4.10 or 3.54, chunks are different.
Old Dec 28, 2010 | 08:40 AM
Purplezr2's Avatar
All 2nd Gen truck that were either manual or 3500 have an D80, I have a manual 2500 and it has a D80
Old Dec 28, 2010 | 08:36 PM
MarkT's Avatar
The ones I have seen for $400-$600 for a 3.54 had not been rebuilt and had many miles on them. I felt I could be in for a steep total if the clutches and other parts were worn out. I have seen some rebuilt ones but they were for 4.10 and up chunk. I have been waiting for a rebuilt clutch type for a 3.54 but by next summer I may just go ahead and get the torsen gear style LS.
