I could be wrong but........
Old Oct 7, 2006 | 02:44 PM
97ramctd's Avatar
Cool I could be wrong but........
I had my wastegate plugged off and it was building to much boost for the poor stock charger. (40-43 PSI) So, i hooked it back up today and i could be wrong but... It seems to run ALOT better, the exhaust up top sounds like it got louder, and its not making a high pitch noise up top anymore..
This all possible with just hookin up the watsegate?
Old Oct 7, 2006 | 05:42 PM
mr T's Avatar
i dunno how much fuel ur pumping into your motor but i think you'd be better off getting an adjustable boost elbow...of ur hitting 40psi or more ur either making some awesome power or overboosting....since enabled the wastegate again does the truck smoke black? if yes then u need more boost
Old Oct 7, 2006 | 07:49 PM
97ramctd's Avatar
yes it does smoke black... and it was smokin black when i had the wastegate plugged off also.
Old Oct 8, 2006 | 08:02 PM
gmctd's Avatar
Entirely possible, and probable - at those pressures, your IATs may be too high for the charge-air cooler to handle.
The lower pressures are resulting in cooler denser air, where the hi-pressures were resulting in hot air - takes more of it to do same work, not even good for power.
yeah - i corrected it - so call me sticks and stones, and throw names!
1972RedNeck
Oct 29, 2013 06:55 PM
dogcamo
Jul 12, 2010 02:14 PM
rjg23
Dec 1, 2008 09:42 AM
Chrisreyn
Oct 22, 2007 03:42 PM
Crimedog
14
Jan 27, 2007 09:42 AM
