How to seperate trans from transfer...?
Old Mar 6, 2006 | 04:42 PM
Greguw's Avatar
Smile How to seperate trans from transfer...?
Hi guys I am trying to remove a transfer case from a 1996 2500 4x4 ...I removed all the lines , wiring , linkage , driveshafts , casebolts .
It still will not come off , the case is lose but seems to be connected.
I even wraped a strap around the case and hooked a ***-a-long for light pulling help ..no go ...am I missing something ...
Thanks
Greg
Old Mar 6, 2006 | 04:57 PM
Geico266's Avatar
When I watched the boys in the shop take it off it just slid off. They had to "bounce" it alittle.
Tranny in neutral? Missed a bolt?
Man, I'm out of ideas.
Bump.
Old Mar 6, 2006 | 06:43 PM
Greguw's Avatar
Smile Re: won't come off
I did the bounce thing ...I did not try trany in neutral ..But that really should not make a differance... I use a big rubber malet to wack it ... I slaped it silly and it still would not budge .
I even used a ***-a-long to pull back on the unit ...all the bolts are off , there's a 1/8 gap all around , seems like it's the driver side more to the top thats holding it .
This is the truck I am parting out ... it was sitting for a while maybe the splines are rusted to the trany shafted ...
I did not know if the was a "e" clip inside the pto access cover or some special trick I'm missing .
Thanks
Greg
Old Mar 7, 2006 | 12:12 AM
cumminsdriver635's Avatar
Mine slid right off the shaft. Be positive you got all 6 nuts off that hold the t-case on.
Eric
Old Mar 7, 2006 | 06:58 PM
Greguw's Avatar
Smile Re : it came off ...
I finally was able to get them seperated ... no rust ... just stuck .
Greg
Old Mar 7, 2006 | 07:00 PM
Geico266's Avatar
Greg
Glad to hear that.
peobryant
Feb 19, 2009 02:06 AM
morkable
ABDTR #5
41
Dec 28, 2008 11:23 AM
rollincoal01
Mar 8, 2008 04:15 PM
User Name:
Jun 9, 2007 02:15 PM
BigDan
May 29, 2006 10:46 AM
