How Much Will A Stock Clutch Hold
Old Mar 22, 2004 | 12:39 PM
jermey1980's Avatar
I NEED TO KNOW HOW MUCH MORE I CAN PUSH THIS STOCK CLUTCH
99 24 VALVE 3/4 4X4 5 SPEED HP INJECTORS, PACBRAKE, ISSPRO GAUGES, EDGE COMP BOX HP INJECTORS AND 4 INCH STRAIGHT PIPE AND AN ADD DEVICE BLOCK WASTEGATE TOTALLY
Old Mar 22, 2004 | 01:29 PM
redramnc's Avatar
Simple answer - until it starts slipping
Non-answer - it depends.
Correct answer - ????????
How you shift, what you pull, where you are (hilly or flat), road miles on it or stop-and-go, all figure into the lifespan equation. From your sig I would say you probably have some room to add HP but maybe not. Maybe somebody else can pin down an ultimate tq/hp number. Might want to try some of the a/m clutch builders' sites to see what they say.
Old Mar 22, 2004 | 02:24 PM
farmer dave's Avatar
Even with those improvements he is still good with a stock clutch?
pwrtripls1
Jan 16, 2008 06:32 PM
ocsurf16
18
Jan 20, 2006 11:16 AM
bigman
Sep 29, 2005 09:39 PM
Bobcat698
21
Aug 26, 2005 01:37 PM
