how much boost is safe?
Old Mar 3, 2007 | 12:48 PM
Cummins Freak's Avatar
just wanting to know whats the effective map range of boost on my HTT Killer B2 64/14 thanks
Old Mar 4, 2007 | 12:46 PM
edy's Avatar
edy
45 psi after that they float the head
Old Mar 4, 2007 | 07:06 PM
olbetsy98_12V's Avatar
I would agree with edy my HG popped at 42psi but that was with the stock turbo. If you get it studded and ringed depending on what size and kind of ring you could hold alot more. Im runnin haisely's firerings and they are supposed to be good till 80psi.
Old Mar 4, 2007 | 07:09 PM
12valve's Avatar
how much psi are you making with the 64 now?
i cant push it past 42 psi high elevation here!!!
Old Mar 5, 2007 | 11:43 AM
Ram of Steel's Avatar
I have had no problems at 40 psi.
Old Apr 18, 2007 | 06:37 PM
oldsmokey97's Avatar
im getting 55psi out of mine with no problems. O-ringed and studded here!
Lance
Old Apr 19, 2007 | 12:50 PM
wildmanben's Avatar
ditto, o-rings and studded, should be near 60 here soon. Probably better adjust the wastegate though...
streetsmoker
28
Sep 29, 2006 07:06 PM
TDRattler
Apr 10, 2006 09:21 AM
crater12
14
Nov 8, 2005 10:09 PM
hopak
Sep 12, 2005 11:46 PM
callum
13
Jun 28, 2004 11:40 AM
