How much boost am I running?
I do not have a boost gauge..... Soooo.... what type of boost do you think I am running....
80 HP injectors
100 plate
timing 15.5
And what could I expect from blocking off the waste gate? I recently had did a new head gasket with screw in studs....
My sigs say the rest of my mods...... thanks..
80 HP injectors
100 plate
timing 15.5
my buddys truck that I just put a 100 plate in can push 43 lbs of boost. This is a 96 5 speed with only 100 plate and timing. My truck, is stil at stock timing with a 0 plate centered and I can only ush about 25 psi, both with blocked wastegates, but I think I my have a boost leak.
Mines wastegated at 34-35psi, It feels like it could go alot more if I adjusted the wastegate but the stock turbo is good right at 34. I don't know if the stock wastegate is adjustable, but ur setup should be the same boost if not alittle more with the injectors to light the turbo some more.
one other thing.....
I had my injection pump rebuilt about 5 months ago. I installed my 3K spring kit and the truck would rev to about 3100 RPMS. After the injection pump build and bumped timing it only rev to about 2850? On a injection pump rebuild would they have to remove the 3K spring kit ? Maybe they adjusted them differently?
Thanks....
Thanks....
Thanks....
Thanks....
boost and rpm range
Truck in neutral I can only get around 2900 RPM's. While driving about the same. Maybe on more click on the GSK's? How much RPM does one click give? I just installed my boost gauge and max boost was 33. I blocked off the waste gate and max is 39.
i would set the max boost at 35psi 39 isn't that bad but i wouldn't go up there too much because the turbo doesn't make maximum power if its over 35psi so i read, and an aftermarket turbo charger shouldn't really change your mpg's but how you drive the truck does alot, more air just makes the truck more efficent so that would help your mpg's wasting less fuel is good.
LooseBoltsRob
31
Nov 16, 2007 02:19 PM
Cumminsdieselboy
Oct 27, 2003 07:36 AM
