How to modify H2 wheels for Dodge hubs ??
Need some ideas for the cheapest/easiest way to correctly modify some H2 wheels to fit on my 94 CTD 4x4. I dont have all the tires yet so its no big rush. Its not going to take much but just wanted it to be right and not grind it out by hand and make future balancing a potential problem. Have access to a hopefully big enough lathe so what would be the best way to chuck up the wheels?, get a old hub and mill down the center to be able get the cutting tool where it needs to be inside the wheel? Are there any 8 lug axles with studs that arent floaters ? Any good ideas? Thanks for any suggestions....
Do a search for hummer wheels and you should find a lot of info about either machining them or using a hole saw on them. I believe the hole size needs to be 4.774 but i cant remember right off hand.
91oldranchtruck
Jan 31, 2011 09:45 AM
cr25ovet
Jan 1, 2005 07:39 AM
cLAYH
Feb 7, 2004 01:28 AM
