How many starters in 2009?
Old Jul 27, 2009 | 04:50 PM
96_12V's Avatar
Some may have read of my 4- year old starter failing this spring. Replaced with a rebuilt unit from O'riely's which failed in less than a week. Replaced that with a "100% factory New" unit from O'riely's (at no charge) and now, three months later, I had to get under the truck today after lunch and tap on the starter to get it to turn over - just a click otherwise.
Fortunetly, our localy O'riely's has a good return policy, and it'll be covered, but gosh - how much practice do I need changing this out? Anyone else been through three starters in less than a year? What an accomplishment....
Old Jul 27, 2009 | 05:10 PM
patdaly's Avatar
Almost sounds like the starter contacts. Might want to take the Solenoid cover off the new one and look at the contacts. I know this, lifetime warranty or not, when I put a new one on Greenie, Foster truck oversized contacts are going in.
seahawkdodge's Avatar
Nope. I have had the same Shucks rebuild in my 98, since 05.
You might want to check your starter bolts. I've had to lock-tite mine, as they have a bad tendency to back out. I only noticed after one fell all the way out, and the other two were loose. The starter lost contact with the bellhousing, and wouldn't crank....
Old Jul 27, 2009 | 07:55 PM
96_12V's Avatar
Any idea where to get these? I might have to install a set.
I'm using the O'riely's in Chillicothe, IL, just a little ways from you...
Thanks for the reply's so far. I'll check the bolts and consider lock-titing them.
Old Jul 27, 2009 | 08:02 PM
mishkaya's Avatar
http://www.fostertruck.com/dodge/default.htm
Have them and love them.
Old Jul 27, 2009 | 10:29 PM
ttcfan4476's Avatar
i am also on my second starter and going to go get my third in the morning
Red3quarter
Jul 11, 2009 10:53 PM
Red3quarter
Jun 7, 2009 02:22 AM
Red3quarter
Apr 18, 2009 11:39 PM
jbjarko
Apr 12, 2009 12:01 AM
