Highway rpms
Old Dec 28, 2011 | 08:11 PM
monstr250's Avatar
Highway rpms
What kind of rpms are you guys running at highway speeds? I've got to check with my gps again but I think I remember being around 2200-2300 around 60 mph. it feels high to me but I've got 35 inch mt, 3.54 gears, and a nice big flat bed. Any input would be great.
Old Dec 28, 2011 | 08:21 PM
oldblues's Avatar
hi
sumpins up there !
i get app 2000 at 65 with 265 70 16 ?
what is your fuel milage , maby no lock up ?
Old Dec 28, 2011 | 08:51 PM
monstr250's Avatar
There is no lock up I've got the A518 trans. I'm not sure of my milage because I don't have an odometer.
Old Dec 28, 2011 | 09:07 PM
oldblues's Avatar
hi
a 94 should have had a l u trany?
those rpm s sound like 4.10 gear ratio or your convertor is out to lunch ?
Old Dec 28, 2011 | 09:34 PM
monstr250's Avatar
Tranny is from my old first gen. Positive its not lock up. I'm going to check out the gears again tomorrow just to be sure I'm correct. The trans was rebuilt about 3 years ago and only about 20,000 miles on it since then.
Old Dec 29, 2011 | 12:41 AM
Tate's Avatar
Sounds like you're not getting to overdrive.
Old Dec 29, 2011 | 09:23 AM
monstr250's Avatar
I've got my od wired to a toggle switch and I can feel it shift in and out just fine.
Old Dec 29, 2011 | 10:19 AM
9812vram's Avatar
2200rpm is probably close without lockup on that A518. I run 1600rpm at just under 60 mph. Can't remember what my gears are. 3. somethin's...
Old Dec 29, 2011 | 08:51 PM
joem's Avatar
1900 @ 75MPH with 33's
Old Dec 29, 2011 | 09:12 PM
monstr250's Avatar
Ok so I verified tonight that I do in fact have 3.54 gears. took the truck out for a spin with the gps but was not a able to get up to 60-65 for any long steady runs due to traffic. But at 55 I was around 2100-2200. The trans shifted fine through all gears.
Old Dec 30, 2011 | 01:29 AM
scjfly's Avatar
That seems weird to me. I have 3.54's and I am at 2000/50 mph in 4th/direct drive. IIRC i am around 1900 running 65 mph. (speeds are indicated)
I realize you are losing some in your torque converter, but I wouldn't have thought that much.
The following link will give you a rough idea where you should be.
http://dodgeram.org/tech/specs/axle/rpm_vs_mph.htm
Old Dec 30, 2011 | 02:04 AM
Robert Rausch's Avatar
My truck with 3.54 runs a little over 1600 rpms at 55.
Old Dec 30, 2011 | 05:59 AM
Don T's Avatar
My truck with 3.54 runs a little over 1600 rpms at 55. and 2000 rpms at 75 mph
Old Dec 30, 2011 | 11:09 AM
flyingd's Avatar
I have 4.10's in my truck with 215/85/16's and at 70 I am at 2300 - 2400 rpm. If you have a non-lock up I would say your TQ is not doing its job very well.
When you rebuilt your trans did you replace your TQ?
Old Dec 30, 2011 | 03:09 PM
Tate's Avatar
That is roughly my RPM when I am in 5th (direct) with 33" tires. I still say you're not getting into OD, or your converter is absolute garbage.
