High oil level 12v
Old May 24, 2013 | 04:53 PM
vssman's Avatar
Question High oil level 12v
I found my oil level to be very high which was, I think, causing the pressure to fluctuate. I'd guess there were at least 4 quarts too much. I believe it's fuel in the oil. Where can it be coming from? Lift pump, injector pump, injectors??? The truck runs great and isn't showing any white smoke leading me to think the LP is leaking fuel. Thoughts?
Old May 24, 2013 | 05:15 PM
patdaly's Avatar
Lift pump would be my first guess. I am pretty sure the P7100 cant leak fuel into the crankcase ( at least I have never heard of one doing it ), and I would say you should hear and feel an Injector leaking that much.
Old May 24, 2013 | 05:43 PM
vssman's Avatar
That's what I'm thinking. I can't imagine injectors leaking or the lift pump and not having it run rough or see white smoke...
Old May 24, 2013 | 07:35 PM
infidel's Avatar
Fuel supply pressure in excess of 45 psi can blow through internal injection pump seals and end up in the oil.
Did you happen to stretch the overflow valve spring?
http://www.cumminsforum.com/forum/94...-12-valve.html
Old May 24, 2013 | 07:44 PM
vssman's Avatar
No, it was replaced a good 10+ years ago but not stretched.
Old May 28, 2013 | 10:53 AM
vssman's Avatar
Leaking through the lift pump... Tipped the pump and fuel poured out the plunger. Who carries the metal line between the lift pump and filter housing?
Old May 28, 2013 | 10:56 AM
infidel's Avatar
Dodge and Cummins
jmccart
Feb 18, 2008 10:27 AM
jmccart
Dec 21, 2007 06:00 PM
z-rider
Jun 19, 2007 05:15 PM
teckert
Jun 9, 2004 12:34 PM
