hi-idle screw
not sure if you are talking about the truck in your signiture, but if you are and the pump is the one that came stock in the truck.. You have a VE pump and will likely be installing the 3200 spring.. What I do is, adjust it while roating the throttle linkage to get full travel.. you will be able to tell while rotating it.. Good luck.. Also, you can move the thottle linkage arm over to the inside hole.. That helps too.. The real smart guys will chime in later!!
Not difficult to install a GSK. About the same challenge as a VE pump. Just requires some mechanical aptitude and common sense.
The high idle screw is better used after a GSK. You can tighten down the top rpm. A 3k (3,000) is better for your motorhome pump.
What transmission do you have in the MH?
The motorhome has the 542 allison 4-speed and no lock-up. Thats why i need more rpm,s plus the stock convertor in these are pretty sloppy. How is the high idle screw better used after the gov spring?
The 3k GSK will give you fueling out to around 3,000 rpm, but you can still get 3,200-3,600 rpm from the engine before the governor limits. High rpm really pushes the limit of a stock turbo.
You can use the fast or high idle stop to keep your governor speed down to around 3,000
jmd4993
Jun 22, 2013 07:36 AM
FlaCracker
Oct 23, 2009 02:42 PM
