Help! Truck won't crank - fishing trip in 4 days - I pull the ATV's
Old Sep 15, 2011 | 11:07 AM
Lyall's Avatar
Unhappy Help! Truck won't crank - fishing trip in 4 days - I pull the ATV's
Truck does not turn over (starter will not engage). A click is heard but no starter - I'm thinking solenoid contacts. Checked the battery voltage and it was 12.8v. Just for interest sake, I tried to jump start it with my VW and it started easy. Both batteries are 1 year old. Was it coincidence that it decided to start with my VW hooked up to it? This happened last week but I let it sit for 2 minutes and it started right away. I want to put a "LarryB's" solenoid/contact kit in but don't think I can get it here (Ottawa, Canada) in time - leaving on trout trip in 4 days. Any ideas or suggestions? Is it possible that something is bleeding my batteries down to the point of no power but still a good voltage reading?
Lyall
bm271@ncf.ca
Old Sep 15, 2011 | 11:38 AM
slevhansen's Avatar
if you put a voltmeter on it, and then turn the key, if batteries are bad you will see voltage drop to like 6 or so volts, if it doesn´t drop, batteries are good and you look for relays or fuses.
That´s a start, hope it helps, gotta get you fishing.....
Old Sep 15, 2011 | 10:19 PM
Tate's Avatar
My last starter failed in a similar fashion. It was hit and miss when it would work and when it wouldn't. The fact that your truck was hooked to the VW could just be a coincidence.
Old Sep 16, 2011 | 12:07 PM
9812vram's Avatar
Two issues with your starter can cause that problem:
1. Burnt or "bad" spot in the starter - sometimes with enough extra voltage and amps it is enough to get it to spin over. Bar the engine over a bit so the starter teeth engage on different teeth in the ring gear. If the teeth are not perfectly lined up it will turn the starter over slightly when the drive teeth meet - sometimes this is enough to get it going. It will work again until the starter stops at the "dead spot" again.
2. Brushes are worn - same story - boosting adds voltage and amperage making just enough connection to get the starter to turn.
Next time it won't start, smack the starter with a hammer a couple times, then see if it starts. If it does - it's brushes.
Hope that helps ya
Old Sep 16, 2011 | 01:07 PM
Lil Dog's Avatar
Get your parts here and just put new contacts in the starter. If the brushes look worn, you can replace them too..
http://www.fostertruck.com/dodge/default.htm
Old Sep 17, 2011 | 07:50 PM
Lyall's Avatar
Thanks Guys - looks like it was the starter contacts - got a rebuild shop to replace the contacts (HD) on the spot for $55 - included testing.
ado2b1
Dec 16, 2008 03:19 PM
Machinos
Mar 16, 2008 01:34 AM
Hoss
Jun 20, 2005 07:26 PM
boiler-rat
Jan 18, 2005 06:49 PM
95ramtough
Nov 19, 2002 10:30 PM
