Help me get my old 12v be a lil bit faster!!
Old May 20, 2008 | 04:05 PM
ronnyenns's Avatar
Hey everyone, i have a 1994 1500 4x4 dodge truck with a 97 12v engine in it (215hp) i have it lightly modded it has aprox 500-600 hp im not very sure cause we dont have a dyno near around here it has new era's 435 injectors, 4k gsk, home made twins (hx35/ht3b) #0 plate and high flow DV's..the best i did was 13.5 seconds 1/4 mile with a 5 speed manual, (thats at 6000 ft. elevation) im converting it to a automatic now with a full goerend transmission also 4x4..but im looking for more power like 800hp on diesel only so i was hoping someone could help me find the right parts and see what i need..im willing to spend enough Buckz
Old May 20, 2008 | 07:16 PM
12valve's Avatar
looking at it run, i think you need more fuel. smoke almost clears... specially since you wanna go bigger on chargers.
I think its time for some mayor pump modding, like sending it to a good pump shop...
even though big HP has been made on a 215 pump. someone else with more info should shime in here...
Old May 20, 2008 | 08:14 PM
ronnyenns's Avatar
yea definetly more fuel..where is a good shop to modd the pump for max fuel? I've heard some pretty good things about Scheid Diesel, anyone who recommends them?
p.s. are my injectors big enough for my aplication?
Old May 20, 2008 | 08:25 PM
dieselman2300's Avatar
Try here. His name is Brad Ponci. He is on here (I think) and for sure on comp. diesel.
Ponci's Diesel Center
770 S Fortuna Blvd
Fortuna, CA 95540
Phone: (707) 725-3307
There is also Columbus Diesel in Ohio.
Old May 20, 2008 | 09:14 PM
ronnyenns's Avatar
Thanks alot Dieselman2300, is there anyone who can tell me what else i need then Fuel? which chargers pistons cam..etc
Old May 20, 2008 | 09:44 PM
Id say you need a bigger top turbo (62/71/13ss) and a bigger bottom turbo (S480).
I would keep the injectors, and get some pump work.
Whats your timing set at?
You will probably lose a second going to an auto.
Old May 21, 2008 | 01:36 AM
ronnyenns's Avatar
ok your saying lose a second going to an auto.. do you mean is it gonna be lower or higher at a 1/4 mile? Sorry i didnt get it.. LOL
And about my timing i dont have the tool set for that, but when the engine and the pump both are at the mark i spin the engine about 1/2 inch reverse, thats how i leave it, does it make any sense to you?
Old May 21, 2008 | 11:38 AM
wcbcruzer's Avatar
He means you'll be faster in the 1/4 mile with an auto.
Old May 21, 2008 | 07:30 PM
ronnyenns's Avatar
oh sweet that sounds better
and where can i get a nice injection timing tool?
Old May 21, 2008 | 08:18 PM
Snap-on sells them.
http://buy1.snapon.com/catalog/item....re&dir=catalog
Old May 22, 2008 | 12:59 PM
12valve's Avatar
X2 on brad ponci's
Old May 23, 2008 | 10:57 AM
ronnyenns's Avatar
Thanks to both of you i bought a snap-on, they cost a little but i think its worth it..
Old May 26, 2008 | 11:27 AM
12valve's Avatar
If you want my 62/12 let me know...
Old May 26, 2008 | 06:45 PM
kelownadiesel's Avatar
that truck will be very very fast with an auto and a built pump.Id go with a 13mm pump and like it was said ,a bigger set of chargers like a b1/b2 set .Im not sure those injectors will be big enough ,but they are a pretty good size.properly set up that truck should run 10's in the 1/4
Old May 27, 2008 | 08:28 PM
ronnyenns's Avatar
wow that are some amazing times, im doin my tranny and after that ill do the rest, and i'll let you know
