Help - Can't get the Crossmember Back In
Help - Can't get the Crossmember Back In!
I had my 47RE out for a TC and VB upgrade, and now I can't seem to get the crossmember support back in. When I took it out it just took a few knocks towards the back and it came right out.
Any advice is appreciated as I'd like to get this truck going again soon.
Thanks.
Thanks.
Use a porta-power to push frame outwards just slightly. Thats they way tranny shops do it. I've done it also.
Or try it at different angles with a BIGGER hammer.
Hope that helps. let us know if you need more.
sometimes getting the xmember to go as far up,,,, and bringing it from the top of the frame and hammering to the bottom sometimes works ,,, the space is sometimes greater at the top than the bottom,,, thats if you don't have a porta power ,,,, but the porta power is much easier,,,
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
I got mine in using a BFH, three sets of eyes and hands (me, my bro-in-law and my dad) and a lot of patients. We went in from the rear, working both sides a little at a time.
I buffed up the xmember and the mouning surface of the frame. Thin layer of grease and came in from the top. The frame and x-member are tapered to saddle in the frame from the top. Straight in isn't gonna work.
Got the crossmember in yesterday with the help of a couple of 2x4's nailed together and a bottle jack. Spread the frame and it dropped right in.
Today, I am enjoying my Goerend Triple Disc TC and VB
Can't believe how tight it is compared to the stock TC, just a touch on the throttle and the truck moves! Tommorow a #10 plate, 3k GSK and AFC kit.
I don't know if this thread is dead or not, but you don't need to use any jacks or spreaders. The crossmember ends are tapered so it will only drop down from the top. I had the same problem and finally after measuring it figured it out. Once I had it positioned correctly, it slid right in.
Hopefully this saves someone else some hassle and doesn't spring the frame.
Paul
Paul
mattk50
Feb 6, 2006 10:49 AM
