Help, 5spd install!
Old Apr 9, 2007 | 05:23 PM
farmer0_1's Avatar
please go step on the pedal and make sure the throw out bearing is still on its pivot before you go and install the transfere case. . trust me .
Old Apr 9, 2007 | 06:13 PM
Box5's Avatar
I installed the trans with the bellhousing on the transmission, so the bearing was already on the retainer, and it slides good. I knocked the pivot off acouple times when I tried to install it bellhousing first. I haven't installed the slave cylinder yet, so I can push the fork back and forth, and it's on the the pivot for sure. I'm gonna go install the master and slave right now, and get that wired up.
Old Apr 9, 2007 | 06:22 PM
Forrest Nearing's Avatar
I'm pretty sure you can just use a pry-bar to actuate the clutch from under the truck
Old Apr 10, 2007 | 12:12 AM
farmer0_1's Avatar
cool just didn't want a repeat of my job. didn't want to nag.
Old Apr 10, 2007 | 09:05 AM
Box5's Avatar
no problem, I like all the input I get. I just double checked it last night after ur post to make sure. I can't wait to get it on the road
Old Apr 12, 2007 | 07:44 AM
pete97's Avatar
Box5, Did you get the truck running? I haven't heard anything lately. Pete
Old Apr 12, 2007 | 08:56 AM
Box5's Avatar
Well, I had to wait a extra day for a new output snap ring for the transfercase, and find a replacement screw for the one I stripped on the oil pump. Got that all buttoned up last night, just need to measure driveshafts today, and I'll probably get them modded tomorrow. Planning to be driving on Saturday. Again, thanks for all the help u and Lewis gave. I just wanna measure that front driveshaft a couple times because it's gotta be dead on. Still waiting on a shiftboot I bought, but thats not gonna stop me from driving it, lol.
Old Apr 12, 2007 | 09:01 AM
Box5's Avatar
here's a few pics from the beggining of the swap... the t-case shift linkage doesn't have the hole drilled yet, but u can see how I welded that extra length tab on it to fit the 5spd.
auto coming out
auto out
trans mount fabbed up
clutch installed
shifter linkage
Old Apr 12, 2007 | 11:54 AM
pete97's Avatar
Looks great. Do you want me to measure my drive shaft and tell you what it is? Pete
Old Apr 12, 2007 | 12:08 PM
Captain's Avatar
I look through the slave cylinder hole in the bell housnig to see the clutch disk and the input shaft splines to make sure there alligned right.
Old Apr 12, 2007 | 02:14 PM
Box5's Avatar
yea, but the fork is right in the way so u can't see the input gear when u get it close to going in. Believe me, I tried every single way that first day. The best way would be to have a helper who can adjust the jack while u get everything else lined up, and it shouldn't be hard at all.
I got the driveshafts measured pete, thanks though. I got 5-7/8" longer in the rear, and 5-1/2" shorter in the front.
Old Apr 12, 2007 | 04:46 PM
Big Smoky's Avatar
What kind of clutch did you put in Box5?
Old Apr 12, 2007 | 05:45 PM
Box5's Avatar
Valair with a 3200# disk
Old Apr 14, 2007 | 01:19 PM
Box5's Avatar
Just drove it around my driveway alittle, I still gotta put the front driveshaft on when they finish it on monday, and put the t-case linkage back in. I'm cutting the hole for the new shift boot right now, Can't wait to get it out on the road and really get through the gears.
Old Apr 14, 2007 | 08:59 PM
farmer0_1's Avatar
nothing like it. good job. now enjoy
