help!!!!
Old Jul 14, 2003 | 10:53 PM
moneypit's Avatar
help!!!!
i am looking for the rear axle mounting hardware for a 97 dodge ram 4x4 i need the plates that go underneath that the u bolts bolt up too also i need some stock rear blocks anyone know where to find some used or new??? thanks Jered
Old Jul 15, 2003 | 09:34 AM
turbodiesel_ram's Avatar
Re:help!!!!
Did you try your local Dodge service center?
Old Jul 15, 2003 | 01:20 PM
Nuttymopar's Avatar
Re:help!!!!
You could also try a local spring repair place. I added a couple of blocks (about 2.5 inch) to my front shaft and only bought new U-bolts and 4 degree shims to go between the blocks and springs to make up for my change. Cost about $50 to lift my front end 2.5 inches to level out the whole truck. They may have the parts you are looking for.
Old Jul 15, 2003 | 09:41 PM
moneypit's Avatar
Re:help!!!!
ok will give it a try thanks
Old Jul 16, 2003 | 08:25 PM
James Lucas's Avatar
Re:help!!!!
Try Kelderman Mfg they take all that stuff off to put on Air-Ride suspensions.<br><br>Kelderman<br><br>James
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
