Heeeeeeeeeeellllllllllllllllllllpppppppppppppp
Was finishing up the brake job. Now can't find the brake shoe guide. Dealer ship say no longer carried. Gulp
This part fit's behind the upper shoes springs and hold the top of the shoes in against the back plate pin. 1994 Ram 2500 drum 13" x 3" with 2 1/2" shoes. Need this ASAP
Is that the little plate with the hole in the middle that sits on the top pin? It isn't really a wearing part, so not sure if it's available in the aftermarket, but I would check at a parts store just in case. If not, a self-serve junkyard would probably have lots. There are probably many different vehicles that would have one that is similar enough to use. You'd just need to bring yours from the other wheel, to use to compare.
