Harm from exhaust brake
Old Jul 12, 2006 | 03:37 PM
ratsun's Avatar
Hey guys I wondered if any long term harm can be done from running a exhaust brake with out the HD valve springs installed on the exhaust valves?
Would it cause premature seal/guide wear, or anyother problems you can think of?
Old Jul 12, 2006 | 06:26 PM
rhino 660's Avatar
piston and valve interference ie can bend your valves.
anyone correct me if i am wrong
Old Jul 12, 2006 | 06:44 PM
infidel's Avatar
You are right. If the back pressure in the exhaust manifold with the e brake closed exceeds the psi rating of the valve springs the valves will float, damage will occur.
Pac-Brakes have a hole drilled in the butterfly to prevent this if you don't want to change springs.
Old Jul 13, 2006 | 03:19 PM
ratsun's Avatar
Yeah I was aware of that type of damage but I wondering more about things like premature guide or seal wear.
Totallyrad
Jan 9, 2013 02:57 PM
latitude500
Mar 11, 2008 08:15 PM
SDHNTR
Jul 13, 2007 08:02 AM
2500TurboDodge
Jun 28, 2005 09:52 PM
