Guys I need a part number
Old Aug 7, 2006 | 09:31 AM
TxDiesel007's Avatar
Guys
Im gettin everything ready to drop the transmission on the truck for this weekend. As i was down there looking yesterday i noticed that where the T case and the Tranmission connect is the source for the massive oil leak that I have had for a couple of weeks now.
My question is, what is it that is in there? is it some sort of a seal? If so do any of you have a part number? or is this seal a dealer only item.
Thanks guys...
Rick
Old Aug 7, 2006 | 09:44 AM
mr T's Avatar
actually i believe that just RTV sealant...i don't know that there is a solid seal there..i have a lil bit of tranny oil accumulating around my seals too..
Old Aug 7, 2006 | 12:19 PM
gmctd's Avatar
Drain the trans, pull the rear housing, clean the surfaces with lacquer thinner, apply new black RTV, re-assemble, refill trans....................
Old Aug 7, 2006 | 02:18 PM
robert chilton's Avatar
Never had luck with the black or blue stuff where oil is present. I always use the copper 777 high temp silicone now with better results. I pretty sure there is a seal on the adapter plate on the transfer case side. I should remember as I just had it apart 2 weeks ago. The case is a cake walk to drop and reinstall without a jack. Dont forget to drain the Xfer case. It will leak all over the place if you forget.
patdaly
Oct 4, 2010 11:40 AM
77machomopar
Jan 24, 2008 05:30 AM
Bushy
Jul 16, 2005 01:50 PM
MR. GADGET
Sep 4, 2003 06:25 AM
rkelso98
Mar 14, 2003 06:15 AM
