grid heater stuck on
Old Sep 4, 2010 | 01:07 PM
cmac's Avatar
but only when the key is on. i disconnected the power for it right at the battery. so i'm guessing that the most likely problem is going to be the relay/solenoid thing on the inner fender..... does that sound right? i dont want to be replacing parts that are still good if i can avoid it.
also when this happened it melted the little boost line that goes from the intake to the injection pump, any one know where i can get that piece?
Thanks
Old Sep 4, 2010 | 06:03 PM
infidel's Avatar
Grids> http://dodgeram.org/tech/dsl/trouble...niford_htr.htm
It's just hose at the AFC, any auto parts will have it.
Old Sep 4, 2010 | 11:33 PM
cmac's Avatar
Thanks! hopefully i can test that stuff tomorrow.
Old Sep 5, 2010 | 02:22 PM
cmac's Avatar
everything tested ok. some bad connections at the relay seems to have fixed the problem, at least for now anyways.
i cant find that hose anywhere online. would you happen to have a part number or a link? thanks
Old Sep 7, 2010 | 09:50 AM
infidel's Avatar
1/8" air brake hose will work.
Old Sep 7, 2010 | 11:26 AM
cmac's Avatar
thanks! the grid's stuck on again, i'm thinking its a faulty relay because they were working again for quite a while then they messed up so i un-hooked them again
Old Sep 7, 2010 | 12:22 PM
infidel's Avatar
Next time the grids are stuck on remove one of the small wires on each relay.
If the grids turn off then the problem isn't the relays and more likely the intake air temp sensor.
If the grids stay on with the small trigger wire disconnected then the problem is a sticking relay.
Much cheaper to replace the relay with a Ford starter relay, $10 at any auto parts.
The Ford relay must be the type with a non-grounded body.
Old Sep 7, 2010 | 03:25 PM
cmac's Avatar
awesome, i'll give that a try. Thanks again!!
Ramrod90
Feb 3, 2009 07:39 AM
jp8819
Oct 10, 2008 06:59 AM
Baja
Jan 29, 2008 08:17 PM
taildragger
Dec 4, 2006 10:00 AM
1955raw
Feb 16, 2006 11:44 PM
