GEN light, alterternator and voltage regulator
Old Jan 24, 2007 | 09:08 AM
pitr's Avatar
So for the last month or 2 the GEN light on my 97 12v has been coming on from time to time, but the volt meter in the dash was still showing it making power.
2 nights ago it fininally died all the way, 0 power. I assumed it was the regulator in the PCM so I swapped it out with an external unit. Still nothing. Pulled the alternator and took it in, it was dead. Swapped in the new one but decided to stay with the external regulator just to avoid future issues and since I already had it all wired and ready.
The problem is the GEN light is still coming on, then going off, then coming on for 5 minute, off for 8, etc, etc. The meter in the cab shows voltage as what I think is a bit high, 15-16, but when I was testing with a real multimeter the in cab meter seemed to be reading high.
So:
What voltage should the alternator be putting out at idle?
At 1500ish RPM?
How much voltage is overcharging/should I worry about?
Does anyone know how exactly the PCM decides to turn on the GEN light?
Thank you much,
-Matt
Old Jan 24, 2007 | 09:21 AM
TIMMY22's Avatar
13.5 to 14.5V
anything over 14.5V for a prolonged period will quickly ruin your batteries.
TurboAZ
Aug 27, 2013 09:26 PM
twavor
Nov 17, 2009 09:27 PM
flycl65
Jan 26, 2006 12:00 AM
freeloader
Mar 28, 2003 09:00 PM
hellotbone
Oct 9, 2002 02:20 PM
