fuel tank problems
Old Apr 25, 2005 | 12:51 AM
halerazor's Avatar
fuel tank problems
i'm having problems with my fuel tank every time i go to put fuel in it, it blows it back out. its like its not releasing the gasses anywhere. its been doing this for a week now then today i looked at my fuel pressue gauge and it was reading 1-2 psi no leaks on the gauge plumming. i'm not sure if the gauge is correct though because i can still get heavy black smoke on acceleration. i think i might have possibly melted a line or something my exhaust came loose under the truck and may have done some damage but the weather has been real crappy and haven't had a chance to look.
Old Apr 25, 2005 | 08:39 AM
BoostdCTD's Avatar
Sounds like your fuel tank's vent line is clogged.
When are you having that pressure? The 12V trucks run a lot higher pressure than that running, I'd suspect your gauge is bad.
Old Apr 25, 2005 | 11:17 AM
halerazor's Avatar
it usually runs around 16psi idle and 22psi cruising no its running 2psi running and goes up to 10psi at idle
Stamey
Jun 27, 2008 02:04 PM
ramsport59
MDDTR #33
Feb 21, 2008 04:15 PM
Mike M
Jun 5, 2006 11:38 AM
ddestruel
Mar 26, 2006 01:54 AM
Toby
Apr 6, 2005 12:31 PM
