Fuel Solenoid problems
Old Dec 14, 2002 | 11:50 PM
hhwright's Avatar
My fuel Solenoid will not work. I have replace the shutdown relay on the firewall, the engine heater solenoid on the firewall, the solenid, and I have switched the relays in the engine distribution. The fuse in the engine distribution box is still good as well. The red wire going to the solenoid shows 12 volts, the white wire shows about 10.4 volts. I have tried to jump start it to get more volts and that doesn't seem to work and the adjustment on the solenoid is correct. If anyone has any suggestions please let me know. This is a 95 12 valve cummings.
Old Dec 15, 2002 | 04:44 AM
dalton4's Avatar
Re:Fuel Solenoid problems
Check the linkage and be sure it is free and not binding or sticking. I had some non-shutdown problems once due to dirty/sticky linkage conditions.
Old Dec 15, 2002 | 03:39 PM
doomgaze's Avatar
I had the same problem on the exact same engine. Took me several LONG months to figure out the problem.<br><br>There should be a blue wire going away from your driver's side battery. Check to see if it is broken. Mine had a burnt out fuse. Replaced the 40 cent fuse and works like new. Found this out AFTER it cost me nearly $800 in &quot;repairs&quot; I didn't need.
dodgediesel
Apr 15, 2010 09:00 PM
jasonfriedlin
Jan 2, 2010 08:24 PM
big jimmy
Oct 24, 2007 08:58 AM
65fury
Jan 21, 2007 10:31 PM
Tim9712v
16
Mar 3, 2005 07:09 PM
