fuel shutoff solenoid i think?
i am looking at buying a 96 2500 and the problem is it wont shutoff to kill it the owner has been popping the clutch. i have not looked at the solenoid yet to see if it has dirt caked around it or not, but it does seem to start ok, any ideas?
Solenoid would generally burn up if that were the case, no? Especially since its not a switch power source, its right from the battery.
You could pull the solenoid off, clean it up and re-install it and it would probably work. But make sure you get some money off the price since it wouldn't pass a safety inspection.
well no not really does it burn up if you leave your truck running for a whole day? but i see what you're saying, sometimes the arc is small enough that any small tap will break the contact. there's not much that is holding the solenoid up being spring loaded in the down position.
If the relay is sticking, its energizing the pull circuit, which draws a lot of amperage (around 70 IIRC). It would be like the starter sticking. The hold circuit is run off of a switched source and is only around 10 amps.
