fuel psi is it ok
Fuel pressure over 45psi can blow out internal injection pump seals or even crack your fuel filter wide open.
Sounds to me like something even worse is going on with the high pressures you're seeing- someone has blocked off the overflow valve entirely or a return line/hose is kinked.
With no return fuel flowing though the pump things can get very hot and dry and cause damage. The P pump isn't entirely oil cooled and lubed.
Either that or your gauge doesn't have a dampener on it and you're reading the high end of the pump spikes or the gauge itself has been destroyed by running without a dampener and isn't reading right.
i streched the spring a little and i have a niddle valve on the guage with a load it goes to about 58 psi but it is not consistint in the morning it does not read that high intell the truck worms up it reads about 45psi
38 Cigarette
16
Aug 28, 2015 11:27 PM
schamran
Dec 14, 2009 08:20 PM
nrussell
Jul 23, 2008 08:58 PM
Tommy93w350
Aug 7, 2007 12:15 PM
Dave88LX
15
Sep 4, 2006 09:30 PM
