fuel problem
Old Jul 17, 2007 | 08:57 PM
deereguy07's Avatar
fuel problem
I have been having this problem for some time now but is just not as bad all the time. I can put my truck in gear or just turn the steering wheel and and the rpm's drop way down.(couple of hundred) At times in gear the truck will die. Idling its fine only when the motor is under a load does it seem like it starving for fuel. If its in gear and you pat the gas most of the time it will die. I put new fuel lines on a couple of months ago. I was having this problem before I put the lines on it. After it worms up it doesn't die but the rpm's just drop a lot. Any thoughts will help. thanks
Old Jul 17, 2007 | 09:04 PM
cheapskate's Avatar
i'm sorry, i can't help, but mine does almost the same thing, so i will be watching this one.
Old Jul 19, 2007 | 04:52 PM
deereguy07's Avatar
bump bump.
Old Jul 19, 2007 | 06:22 PM
clutch1's Avatar
how does the truck start? any probs there.
Old Jul 19, 2007 | 08:42 PM
cheapskate's Avatar
ok, let me just hijack this thread by saying than mine likes to start by giving it a little throttle, and then, if started cold, misses or sputters a little for the first second or two.
Old Jul 19, 2007 | 08:50 PM
clutch1's Avatar
i've never had this problem so ill start from scratch, first you need to make sure you have apropriate fuel to the injection pump. then you need to check fuel psi.
Old Jul 19, 2007 | 09:03 PM
cheapskate's Avatar
yeah, ive been meaning to put a fuel pressure gauge on for a while. i suppose i will piece on together tommorow with an oil pres. gauge and a snubber on the banjo.
Old Jul 19, 2007 | 09:13 PM
shooter_d's Avatar
This might seem a little novice, but my truck was doing the same thing. I'd put it in gear and turn the wheels even a little and it would die. Turned out the lock nut on my idle screw was loose. The thing creeped down ever so slowly and I didn't even notice. I reset the idle to the appropriate RPM, tightened the nut, and haven't had a problem since. Hope this helps.
Old Jul 19, 2007 | 10:03 PM
deereguy07's Avatar
Ok the truck starts fine. I don't have a fuel pressure gauge in it wanting to get one. I had a friend of mine tell me tonight to check the idle. May try to bump it up to 750 or 800 rpms. Have to wait till this weekend the truck is at a friends shop welding up the cab (had a custom x-cab) and doing some little stuff.
Old Jul 19, 2007 | 10:26 PM
clutch1's Avatar
if your gonna bump it up to 750 where is it now?
Old Jul 20, 2007 | 10:53 PM
deereguy07's Avatar
I think its around 650 or 675 something like that. gonna try to fix that and put the traction bars on in the morning.
Old Jul 22, 2007 | 11:03 AM
patdaly's Avatar
Get it up to at least 750 in gear, AC on...... When I got mine, the Dealer had it set down for "that nice low Cummins idle"
It would do the exact things you are describing......... I finally got it set properly and it hasn't done it since.
Old Jul 22, 2007 | 01:50 PM
deereguy07's Avatar
I played with it some yesterday. Its about 700 now give or take a few. Gotta mess with it some more next saturday and try to get it set up some more. I've got my a/c compressor unplugged because it was wanting to lock up didn't have the money to fix it then while I was in collage. thats not very high on the list of things to fix since I got a new truck Lol.
CTD23
Jun 9, 2006 09:32 PM
Checkmate
Mar 5, 2005 08:36 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
