Fuel Pick-up Tubes
Old Aug 12, 2006 | 09:46 AM
pullmaxdude's Avatar
Fuel Pick-up Tubes
Has anyone ever replaced the pick-up tubes in the fuel tank???? I replaced the lines last night and low and behold, when I put pressure on the system, the suction tube has a crack in it right at the bend, and is very rusty. With that being said I call this morning, am told it is dealer only, must replace complete module $312.00. Does this sound correct????
Old Aug 12, 2006 | 10:15 AM
infidel's Avatar
That sounds right.
If you want to save some money give J-B Weld a try.
Old Aug 14, 2006 | 04:48 AM
Thanx Bill, I ended up with a module from the bone yard. nice looking piece. Mission COMPLETE!!!!!!
Old Aug 14, 2006 | 06:41 AM
schoust's Avatar
Hey pull I need to replace my lines also how did you go about doing it and what did you use for material?
Old Aug 14, 2006 | 07:39 AM
signature600's Avatar
Vulcan Draw Straw
When I get a chance, I'm putting one of these in each truck! Replaces the factory pickup tube, and I can run 1/2" hydraulic hose all the way to the lift pump...I get it cheap
Chris
Old Aug 14, 2006 | 10:00 AM
infidel's Avatar
Chris
Be careful Chris, most hydraulic hose is not compatible with diesel fuel.
Old Aug 14, 2006 | 10:09 AM
What's the difference between hydraulic oil, and diesel fuel?? I sould think if it will hold high preesure oil, it would handle low pressure fuel?
Can you straighten me out Bill??
Chris
Old Aug 14, 2006 | 11:08 AM
I used 3/8 on the supply side and 5/16 on return side. Diesel rated marine hose. NAPA has the quick connect adapters that go right on tank tubes. Needed to change the fitting on lift pump, because I am no longer useing the heater/pre-filter. If you pop the d.s. inner fender out makes it pretty easy. I ran the hoses down the frame and tied them off on the original steel lines. If you have an extra fuel cap, drill it and set it up with a regulator so you can prime the fuel system with 10psi max, losen the the bleeder on top of filter. Makes the re-priming much easier. (THANX Bill / Infidel ) !!!!!!!
Old Aug 14, 2006 | 11:13 AM
Also...should I keep the fuel heater?? I can't see it being a problem here in Ohio...we are in the 20's most of the winter, and our fuel is treated!
Chris
Old Aug 14, 2006 | 04:40 PM
WVAussie's Avatar
Just ordered one of those draw straws and the hose in the tank is nylon, diesel safe. Thanks for the link.
Old Aug 14, 2006 | 06:49 PM
infidel's Avatar
Chris
Diesel fuel is incompatible with a lot more materials than oils or gasoline. I've seen diesel melt a lot of materials that I thought would be fine. I'm sure there is a chemical reason for it but it beats me.
Here's a compatability chart for o-rings and diesel that may help. You'll have to find out what the hydraulic hose is made out of first.
http://www.efunda.com/designstandard...C=Diesel%20Oil
Old Aug 14, 2006 | 06:55 PM
Thanks Bill...I'll do a little checking with Weatherhead and see what I can come up with!
Is there anything on the trucks you don't know something about??
Chris
Old Aug 14, 2006 | 07:12 PM
infidel's Avatar
Chris
Chris, unfortunately there are a lot of things I learned the hard way...
Old Aug 15, 2006 | 07:33 AM
schoust's Avatar
Hey Pull,Silly question but how do you get the inner fender out?Also how much hose do I need?I Live in the Boondocks and I want to make sure I have all that I need when I do the job....Thanks
Old Aug 15, 2006 | 07:36 AM
We appreciate it Bill Keep up the good (??) work
Chris
